Command reference
system license show
Display licenses
The ` system license show ` command displays the information about licenses in the system.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-serial-number <text>] - Serial Number
If you use this parameter, the command displays information only about the licenses that matches the serial number you specify.
[-package <Licensable Package>] - Package
If you use this parameter, the command displays information only about the specified package.
[-owner <text>] - Owner
If you use this parameter, the command displays information only about the packages that matches the owner name you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>] - Expiration
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
[-description <text>] - Description
If you use this parameter, the command displays information only about the licenses that matches the description you specify.
[-type {license|site|demo|subscr|capacity|capacity-per-term|enabled}] - Type
If you use this parameter, the command displays information only about the licenses that have the license type you specify.
[-customer-id <text>] - Customer ID
If you use this parameter, the command displays information only about the licenses that have the customer-id you specify.
[-installed-license <text>] - Installed License Name
If you use this parameter, the command displays information only about the licenses that match the installed license you specify.
[-host-id <text>] - Host Id
If you use this parameter, the command displays information only about the license that have the host id you specify.
[-capacity {<integer>[KB|MB|GB|TB|PB]}] - License Capacity
If you use this parameter, the command displays information only about the licenses that match the capacity you specify.
The following example displays information about all licensed packages in the cluster:
cluster1::> system license show
Serial Number: 1-81-0000000000000001122334455
Owner: node2
Installed License: Legacy Key
Capacity: -
Package           Type     Description           Expiration
NFS               license  NFS License           -
CIFS              license  CIFS License          -
iSCSI             license  iSCSI License         -
SnapRestore       license  SnapRestore License   -
FlexClone         license  FlexClone License     -
S3                license  S3 License            -
Serial Number: 123456789
Owner: node1
Installed License: Core Bundle
Capacity: 10TB
NFS               capacity NFS License           -
CIFS              capacity CIFS License          -
iSCSI             capacity iSCSI License         -
SnapRestore       capacity SnapRestore License   -
FlexClone         capacity FlexClone License     -
S3                capacity S3 License            -
12 entries were displayed.
