storage aggregate efficiency stat
Display aggregate storage efficiency statistics
The storage aggregate efficiency stat command displays storage efficiency statistics.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-aggregate <aggregate name>]- Aggregate
If this parameter is specified, the command displays storage efficiency statistics for the specified aggregate.
- [-node {<nodename>|local}]- Node
If this parameter is specified, the command displays storage efficiency statistics for the aggregates that are located on the specified node.
- [-total-blocks-recompressed <integer>]- Total Number of Blocks Recompressed
This field represents the total number of blocks recompressed. If this parameter is specified, the command displays storage efficiency statistics that match the specified block count.
- [-active-blocks-recompressed <integer>]- Number of Active Blocks Recompressed
This field represents the total number of hot blocks recompressed. If this parameter is specified, the command displays storage efficiency statistics that match the specified block count.
- [-inactive-blocks-recompressed <integer>]- Number of Inactive Blocks Recompressed
This field represents the total number of cold blocks recompressed. If this parameter is specified, the command displays storage efficiency statistics that match the specified block count.
The following example displays storage efficiency statistics for all the aggregates that are owned by nodes in the local cluster:
cluster1:::> storage aggregate efficiency stat
Aggregate: aggr1
                                       Node: node1
  Total Number of Blocks Recompressed: 512
       Number of Active Blocks Recompressed: 120
     Number of Inactive Blocks Recompressed: 392
Aggregate: aggr2
                                       Node: node1
  Total Number of Blocks Recompressed: 0
       Number of Active Blocks Recompressed: 0
     Number of Inactive Blocks Recompressed: 0
2 entries were displayed.
 PDFs
PDFs
