volume efficiency policy show
Show efficiency policies
The volume efficiency policy show command displays information about efficiency policies. By default, the command displays the following information about all policies:
Vserver: Name of the Vserver that the policy belongs to.
Policy Name: Efficiency policy name.
Job Schedule: Job schedule name.
Duration (Hours): The duration in hours that the efficiency operation can run.
Enable: Whether the policy is enabled or not.
Comment: User specified comment.
You can specify additional parameters to select the displayed information. For example, to display efficiency policies only with duration 5 hours, run the command with the -duration 5 parameter.
The pre-defined policies default and inline-only are available when all the nodes in the cluster are running Data ONTAP version 8.3 or later.
The inline-only pre-defined policy must be used when the user wants to use the inline compression feature without any regularly scheduled or manually started background storage efficiency operations. When a volume is configured to use the inline-only efficiency policy, the system will stop monitoring changes to the data for running the background efficiency operations on the volume. Volumes cannot be configured with the inline-only policy if there is a currently active background efficiency operation.
[-fields <fieldname>,…] -
Selects the fields to be displayed. Vserver and policy are the default fields (see example).
[-instance ]} -
If this parameter is specified, the command displays information about all entries.
[-vserver <vserver name>]- Vserver-
Selects information about the policies that match the specified Vserver.
[-policy <text>]- Efficiency Policy Name-
Selects information about the policies that match the specified policy name.
[-type {threshold|scheduled}]- Policy Type-
Selects information about the policies that match the specified policy type. There are two possible values -
thresholdandscheduled. [-schedule <text>]- Job Schedule Name-
Selects information about the policies that match the specified schedule.
[-duration <text>]- Duration-
Selects information about the policies that match the specified duration hours.
[-start-threshold-percent <percent>]- Threshold Percentage-
Selects information about the policies that match the specified start-threshold-percent. Valid only if
-typeparameter is set asthreshold. [-qos-policy {background|best_effort}]- QoS Policy-
Selects information about the policies that match the specified throttling method. The values can be
backgroundorbest-effort. [-enabled {true|false}]- Enabled-
Selects information about the policies that have the specified enabled setting.
[-comment <text>]- Comment-
Selects information about the policies that match the specified comment.
[-policy-owner {cluster-admin|vserver-admin}]- Owner of the Policy-
Selects information about the policies that match the specified owner. The values can be
cluster-adminorvserver-admin.
The following example shows all the efficiency policies with the matching Vserver vs1.
cluster1::> volume efficiency policy show -vserver vs1
Policy Job Duration
Vserver Name Schedule (Hours) QoS Policy Enabled Comment
vs1 default daily - best_effort true Default policy
vs1 inline-only - - - - Inline-Only
policy
vs1 policy1 daily - best_effort true user-defined
3 entries were displayed.
The following example shows all the policies with the following fields - Vserver (default), policy (default) and duration.
cluster1::> volume efficiency policy show -fields duration vserver policy duration ------- ------- -------- vs1 default - vs1 inline-only - vs1 policy1 - 3 entries were displayed.
