volume efficiency policy show
PDF of this doc site
Creating your file...
Show efficiency policies
The volume efficiency policy show
command displays information about efficiency policies. By default, the command displays the following information about all policies:
Vserver: Name of the Vserver that the policy belongs to.
Policy Name: Efficiency policy name.
Job Schedule: Job schedule name.
Duration (Hours): The duration in hours that the efficiency operation can run.
Enable: Whether the policy is enabled or not.
Comment: User specified comment.
You can specify additional parameters to select the displayed information. For example, to display efficiency policies only with duration 5 hours, run the command with the -duration 5
parameter.
The pre-defined policies default
and inline-only
are available when all the nodes in the cluster are running Data ONTAP version 8.3 or later.
The inline-only
pre-defined policy must be used when the user wants to use the inline compression feature without any regularly scheduled or manually started background storage efficiency operations. When a volume is configured to use the inline-only
efficiency policy, the system will stop monitoring changes to the data for running the background efficiency operations on the volume. Volumes cannot be configured with the inline-only
policy if there is a currently active background efficiency operation.
[-fields <fieldname>,…]
Selects the fields to be displayed. Vserver and policy are the default fields (see example).
[-instance ]
If this parameter is specified, the command displays information about all entries.
[-vserver <vserver name>]
- Vserver-
Selects information about the policies that match the specified Vserver.
[-policy <text>]
- Efficiency Policy Name-
Selects information about the policies that match the specified policy name.
[-type <Efficiency policy type>]
- Policy Type-
Selects information about the policies that match the specified policy type. There are two possible values -
threshold
andscheduled
. [-schedule <text>]
- Job Schedule Name-
Selects information about the policies that match the specified schedule.
[-duration <text>]
- Duration-
Selects information about the policies that match the specified duration hours.
[-start-threshold-percent <percent>]
- Threshold Percentage-
Selects information about the policies that match the specified start-threshold-percent. Valid only if
-type
parameter is set asthreshold
. [-qos-policy <Efficiency QoS policy>]
- QoS Policy-
Selects information about the policies that match the specified throttling method. The values can be
background
orbest-effort
. [-enabled {true|false}]
- Enabled-
Selects information about the policies that have the specified enabled setting.
[-comment <text>]
- Comment-
Selects information about the policies that match the specified comment.
[-policy-owner {cluster-admin|vserver-admin}]
- Owner of the Policy-
Selects information about the policies that match the specified owner. The values can be
cluster-admin
orvserver-admin
The following example shows all the efficiency policies with the matching Vserver vs1.
cluster1::> volume efficiency policy show -vserver vs1 Policy Job Duration Vserver Name Schedule (Hours) QoS Policy Enabled Comment -------- ------------ ---------- -------- ----------- -------- -------------- vs1 default daily - best_effort true Default policy vs1 inline-only - - - - Inline-Only policy vs1 policy1 daily - best_effort true user-defined 3 entries were displayed.
The following example shows all the policies with the following fields - Vserver (default), policy (default) and duration.
cluster1::> volume efficiency policy show -fields duration vserver policy duration ------- ------- -------- vs1 default - vs1 inline-only - vs1 policy1 - 3 entries were displayed.
