volume conversion validation show
PDF of this doc site
Creating your file...
Show the result of volume conversion pre checks.
The volume conversion validation show
command displays the results of volume conversion validation for volumes.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver (privilege: advanced)-
If this parameter is specified, the command displays information only about the conversion operations that are running on volumes on the specified Vserver.
[-volume <volume name>]
- Volume (privilege: advanced)-
If this parameter is specified, the command displays information only about the conversion operations on the specified volume.
[-precheck <Volume conversions pre check>]
- Volume Feature (privilege: advanced)-
If this parameter is specified, the command displays information only about the specified conversion pre checks.
[-status <Feature status for volume conversion>]
- Feature Status (privilege: advanced)-
If this parameter is specified, the command displays information only about the conversion pre checks with the specified status. The supported statuses are:
supported -The volume can be converted.
warn - The volume can be converted, though there may be an issue highlighted by a warning in the
error
value. -
block - The volume cannot be converted until the specified
action
is taken -
unsupported - The volume cannot be convernted.
error - There was an error performing the pre check.
[-error <text>]
- Feature Error (privilege: advanced)-
If this parameter is specified, the command displays information only about the conversion pre checks with the specified error message.
[-action <text>]
- Feature Action (privilege: advanced)-
If this parameter is specified, the command displays information only about the onversion pre checks with the specified resolution action.
The following example displays all conversion pre checks
cluster::*> volume conversion validation show
The following example displays all conversion pre checks that block conversion until an action is taken, for volume 'vol1' in Vserver 'vs0'
cluster::*> volume conversion validation show -vserver vs0 -volume vol1 -status block
