ONTAP commands
volume conversion validation show
Show the result of volume conversion pre checks.
The volume conversion validation show command displays the results of volume conversion validation for volumes.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver (privilege: advanced)
If this parameter is specified, the command displays information only about the conversion operations that are running on volumes on the specified Vserver.
[-volume <volume name>] - Volume (privilege: advanced)
If this parameter is specified, the command displays information only about the conversion operations on the specified volume.
[-precheck <Volume conversions pre check>] - Volume Feature (privilege: advanced)
If this parameter is specified, the command displays information only about the specified conversion pre checks.
[-status <Feature status for volume conversion>] - Feature Status (privilege: advanced)
If this parameter is specified, the command displays information only about the conversion pre checks with the specified status. The supported statuses are:
  • supported -The volume can be converted.
  • warn - The volume can be converted, though there may be an issue highlighted by a warning in the error value.
  • block - The volume cannot be converted until the specified action is taken
  • unsupported - The volume cannot be convernted.
  • error - There was an error performing the pre check.
[-error <text>] - Feature Error (privilege: advanced)
If this parameter is specified, the command displays information only about the conversion pre checks with the specified error message.
[-action <text>] - Feature Action (privilege: advanced)
If this parameter is specified, the command displays information only about the onversion pre checks with the specified resolution action.
The following example displays all conversion pre checks
cluster::*> volume conversion validation show
The following example displays all conversion pre checks that block conversion until an action is taken, for volume 'vol1' in Vserver 'vs0'
cluster::*> volume conversion validation show -vserver vs0 -volume vol1 -status block
