volume conversion validation show
Show the result of volume conversion pre checks.
The volume conversion validation show
command displays the results of volume conversion validation for volumes.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If this parameter is specified, the command displays information only about the conversion operations that are running on volumes on the specified Vserver.
[-volume <volume name>]
- Volume-
If this parameter is specified, the command displays information only about the conversion operations on the specified volume.
[-precheck <Volume conversions pre check>]
- Volume Feature-
If this parameter is specified, the command displays information only about the specified conversion pre checks.
[-status <Feature status for volume conversion>]
- Feature Status-
If this parameter is specified, the command displays information only about the conversion pre checks with the specified status. The supported statuses are:
supported -The volume can be converted.
warn - The volume can be converted, though there may be an issue highlighted by a warning in the
error
value. -
block - The volume cannot be converted until the specified
action
is taken -
unsupported - The volume cannot be convernted.
error - There was an error performing the pre check.
[-error <text>]
- Feature Error-
If this parameter is specified, the command displays information only about the conversion pre checks with the specified error message.
[-action <text>]
- Feature Action-
If this parameter is specified, the command displays information only about the onversion pre checks with the specified resolution action.
The following example displays all conversion pre checks
cluster::*> volume conversion validation show
The following example displays all conversion pre checks that block conversion until an action is taken, for volume 'vol1' in Vserver 'vs0'
cluster::*> volume conversion validation show -vserver vs0 -volume vol1 -status block
