volume conversion validation show
Show the result of volume conversion pre checks.
The volume conversion validation show command displays the results of volume conversion validation for volumes.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver (privilege: advanced)-
If this parameter is specified, the command displays information only about the conversion operations that are running on volumes on the specified Vserver.
[-volume <volume name>]- Volume (privilege: advanced)-
If this parameter is specified, the command displays information only about the conversion operations on the specified volume.
[-precheck <Volume conversions pre check>]- Volume Feature (privilege: advanced)-
If this parameter is specified, the command displays information only about the specified conversion pre checks.
[-status <Feature status for volume conversion>]- Feature Status (privilege: advanced)-
If this parameter is specified, the command displays information only about the conversion pre checks with the specified status. The supported statuses are:
supported -The volume can be converted.
warn - The volume can be converted, though there may be an issue highlighted by a warning in the
errorvalue. -
block - The volume cannot be converted until the specified
actionis taken -
unsupported - The volume cannot be convernted.
error - There was an error performing the pre check.
[-error <text>]- Feature Error (privilege: advanced)-
If this parameter is specified, the command displays information only about the conversion pre checks with the specified error message.
[-action <text>]- Feature Action (privilege: advanced)-
If this parameter is specified, the command displays information only about the onversion pre checks with the specified resolution action.
The following example displays all conversion pre checks
cluster::*> volume conversion validation show
The following example displays all conversion pre checks that block conversion until an action is taken, for volume 'vol1' in Vserver 'vs0'
cluster::*> volume conversion validation show -vserver vs0 -volume vol1 -status block
