storage raid-options show
PDF of this doc site
Creating your file...
Display RAID options
The storage raid-options show
command displays information about all the RAID options in a cluster. The options are described in the storage raid-options
manual page.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects information about all the RAID options on the specified node.
[-name <text>]
- Option Name-
Selects information about the RAID options that have the specified name.
[-value <text>]
- Option Value-
Selects information about all the RAID options that have the specified value.
[-recommended-value <text>]
- Recommended Value-
Selects information about all the RAID options that have the specified recommended value.
[-constraint <text>]
- Option Constraint-
Selects information about all the RAID options that have the specified constraint. The 'constraint' field indicates the expected setting for a RAID option across both nodes of an HA pair. The possible values are:
none
- no constraint on the value of this RAID option; nodes can have different values -
same_preferred
- the same value should be used on both nodes of an HA pair, otherwise the next takeover may not function correctly -
same_required
- the same value must be used on both nodes of an HA pair, otherwise the next takeover will not function correctly -
only_one
- the same value should be used on both nodes of an HA pair. If the values are different and a takeover is in progress, the value of the RAID option on the node that is taking over will be used -
unknown
- no information about constraints for this RAID option
The following example shows the RAID scrub settings for a node named node1:
cluster1::> storage raid-options show -node node1 -name raid.scrub* Current Recommended Node Option Value Value Constraint -------- ------------------------------------- ------------ ----------- ----------- node1 raid.scrub.perf_impact low low only_one node1 raid.scrub.enable on off none 2 entries were displayed.
