ONTAP commands
storage raid-options show
Display RAID options
The storage raid-options show command displays information about all the RAID options in a cluster. The options are described in the storage raid-options manual page.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects information about all the RAID options on the specified node.
[-name <text>] - Option Name
Selects information about the RAID options that have the specified name.
[-value <text>] - Option Value
Selects information about all the RAID options that have the specified value.
[-recommended-value <text>] - Recommended Value
Selects information about all the RAID options that have the specified recommended value.
[-constraint <text>] - Option Constraint
Selects information about all the RAID options that have the specified constraint. The 'constraint' field indicates the expected setting for a RAID option across both nodes of an HA pair. The possible values are:
  • none - no constraint on the value of this RAID option; nodes can have different values
  • same_preferred - the same value should be used on both nodes of an HA pair, otherwise the next takeover may not function correctly
  • same_required - the same value must be used on both nodes of an HA pair, otherwise the next takeover will not function correctly
  • only_one - the same value should be used on both nodes of an HA pair. If the values are different and a takeover is in progress, the value of the RAID option on the node that is taking over will be used
  • unknown - no information about constraints for this RAID option
The following example shows the RAID scrub settings for a node named node1:
cluster1::> storage raid-options show -node node1 -name raid.scrub*
                                               Current      Recommended
Node     Option                                Value        Value         Constraint
node1    raid.scrub.perf_impact                low          low           only_one
node1    raid.scrub.enable                     on           off           none
2 entries were displayed.
