storage array config show
Display connectivity to back-end storage arrays.
The storage array config show command displays information about how the storage arrays connect to the cluster, LUN groups, number of LUNS, and more. Use this command to validate the configuration and to assist in troubleshooting.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-switch ]
If you specify this parameter, switch port information is shown.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Controller Name
Selects the arrays that match this parameter value.
- [-group <integer>]- LUN Group
Selects the arrays that match this parameter value. A LUN group is a set of LUNs that shares the same path set.
- [-target-wwpn <text>]- Array Target Ports
Selects the arrays that match this parameter value (the World Wide Port Name of a storage array port).
- [-initiator <text>]- Initiator
Selects the arrays that match this parameter value (the host bus adapter that the clustered node uses to connect to storage arrays).
- [-array-name <array name>]- Array Name
- [-target-side-switch-port <text>]- Target Side Switch Port
- [-initiator-side-switch-port <text>]- Initiator Side Switch Port
- [-lun-count <integer>]- Number of array LUNs
- [-ownership {all|assigned|unassigned}]- Ownership
cluster1::> storage array config show
             LUN   LUN
Node         Group Count                   Array Name       Array Target Port Initiator
 vnv3070f19a     0    20                  DGC_RAID5_1        5006016030229f13        0d
                                                             5006016130229f13        0c
                                                             5006016830229f13        0b
                                                             5006016930229f13        0a
                 1    21               HITACHI_OPEN_1        50060e80034fe704        0c
        0d
                                                             50060e80034fe714        0a
        0b
                                                             50060e80034fe715        0b
                                                             50060e80034fe716        0c
        0d
                 2     8              EMC_SYMMETRIX_1        50060482cb1bce1d        0a
        0b
                                                             5006048acb1bce0c        0c
        0d
                 3    10         IBM_UniversalXport_1        202600a0b8322d10        0c
        0d
                                                             204700a0b8322d10        0a
        0b
 vnv3070f19b     0    20                  DGC_RAID5_1        5006016030229f13        0d
                                                             5006016130229f13        0c
                                                             5006016830229f13        0b
                                                             5006016930229f13        0a
        0d
                                                             50060e80034fe714        0a
        0b
                                                             50060e80034fe715        0b
                                                             50060e80034fe716        0c
        0d
        0b
                                                             5006048acb1bce0c        0c
        0d
        0d
                                                             204700a0b8322d10        0a
        0b
38 entries were displayed.
Warning: Configuration errors were detected.  Use 'storage errors show' for detailed information.
 PDFs
PDFs
