storage disk removeowner
PDF of this doc site
Creating your file...
Your file is ready
Remove disk ownership
The storage disk removeowner
command removes ownership from a specified disk. Then disk can then be reassigned to a new owner.
-disk <disk path name>
- Disk Name-
This specifies the disk whose ownership is to be removed.
The following example removes the ownership from a disk named 1.1.27.
cluster1::> storage disk removeowner -disk 1.1.27
