      storage disk removeowner
Remove disk ownership
The storage disk removeowner command removes ownership from a specified disk. Then disk can then be reassigned to a new owner.
- -disk <disk path name>- Disk Name
This specifies the disk whose ownership is to be removed.
The following example removes the ownership from a disk named 1.1.27.
cluster1::> storage disk removeowner -disk 1.1.27
 PDFs
PDFs
