The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage disk removeowner
PDF of this doc site
Creating your file...
Your file is ready
Remove disk ownership
The storage disk removeowner
command removes ownership from a specified disk. Then disk can then be reassigned to a new owner.
-disk <disk path name>
- Disk Name-
This specifies the disk whose ownership is to be removed.
The following example removes the ownership from a disk named 1.1.27.
cluster1::> storage disk removeowner -disk 1.1.27
