security protocol modify
Modify application configuration options
The security protocol modify command modifies the existing cluster-wide configuration of RSH and Telnet. Enable RSH and Telnet in the cluster by setting the enabled field as true .
-application <text>- application (privilege: advanced)-
Selects the application. Supported values are
rshandtelnet. [-enabled {true|false}]- enabled (privilege: advanced)-
Enables or disables the corresponding application. The default value is
false.
The following command enables RSH in the cluster. The default setting for RSH is false :
cluster1::> security protocol modify -application rsh -enabled true
The following command enables Telnet in the cluster. The default setting for Telnet is false :
cluster1::> security protocol modify -application telnet -enabled true
