ONTAP 9.13.1 commands
network bgp config modify
Modify BGP configuration
The network bgp config modify command is used to modify a node's border gateway protocol (BGP) configuration.
-node {<nodename>|local} - Node
This parameter specifies the node on which BGP configuration will be modified.
[-asn <integer>] - Autonomous System Number
This parameter specifies the autonomous system number (ASN). The ASN attribute is a positive integer of the range from 1 to 4,294,967,295. It should typically be chosen from RFC6996 "Autonomous System (AS) Reservation for Private Use" or the AS number assigned to the operator's organization.
[-hold-time <integer>] - Hold Time
This parameter specifies the hold time in seconds.
[-router-id <IP Address>] - Router ID
This parameter specifies the local router ID. The router-id value takes the form of an IPv4 address.
cluster1::> network bgp config modify -node node1 -router-id 1.1.1.1 -asn 20
