system configuration backup rename
PDF of this doc site
Creating your file...
Your file is ready
Rename a configuration backup
The system configuration backup rename
command changes the file name of a configuration backup file.
Use the system configuration backup show command to display configuration backups to rename.
-node {<nodename>|local}
- Node (privilege: advanced)-
Use this parameter to specify the name of the source node where the configuration backup currently exists.
-backup <text>
- Backup Name (privilege: advanced)-
Use this parameter to specify the name of the configuration backup file to rename.
-new-name <text>
- New Name (privilege: advanced)-
Use this parameter to specify a new name for the configuration backup file.
The following example renames the saved configuration file download.config.7z
on the node node1
to test.config.7z
cluster1::*> system configuration backup rename -node node1 -backup download.config.7z -new-name test.config.7z
