volume autosize
PDF of this doc site
Creating your file...
Set/Display the autosize settings of the flexible volume.
The volume autosize
command allows the user to specify the maximum size that a volume automatically grows to when it is out of space or the minimum size that it shrinks to when the amount of used space is below a certain threshold. If only the volume/Vserver name is specified, then the current settings are displayed. This command is not supported on infinite volumes.
-vserver <vserver name>
- Vserver Name-
Use this parameter to specify the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This parameter specifies the volume for which the user wants to set or display the autosize configuration.
[-maximum-size {<integer>[KB|MB|GB|TB|PB]}]
- Maximum Autosize -
Use this parameter to specify the maximum size to which a flexible volume can grow. The default for flexible volumes is 120% of the volume size. If the value of this parameter is invalidated by manually growing the volume to a size more than the value of the maximum size, the maximum size is reset to 120% of the volume size. The value for
-maximum-size
cannot be set larger than the platform-dependent maximum flexible volume size. If you specify a larger value, the value of-maximum-size
is automatically reset to the supported maximum without returning an error. [-minimum-size {<integer>[KB|MB|GB|TB|PB]}]
- Minimum Autosize-
This parameter specifies the minimum size to which the volume can automatically shrink. If the volume was created with the
grow_shrink
autosize mode enabled, then the default minimum size is equal to the initial volume size. If the value of the-minimum-size
parameter is invalidated by a manual volume resize or is invalid when autosize is enabled, the minimum size is reset to the volume size. This parameter is not supported on infinite volumes. [-grow-threshold-percent <percent>]
- Grow Threshold Used Space Percentage-
This parameter specifies the used space threshold for the automatic growth of the volume. When the volume’s used space becomes greater than this threshold, the volume will automatically grow unless it has reached the maximum autosize. This parameter is not supported on infinite volumes.
[-shrink-threshold-percent <percent>]
- Shrink Threshold Used Space Percentage-
This parameter specifies the used space threshold for the automatic shrinking of the volume. When the amount of used space in the volume drops below this threshold, the volume will shrink unless it has reached the specified minimum size. This parameter is not supported on infinite volumes.
[-mode {off|grow|grow_shrink}]
- Autosize Mode-
This parameter specifies the autosize mode for the volume. The supported autosize modes are:
off
- The volume does not grow or shrink in size in response to the amount of used space. -
grow
- The volume will automatically grow when used space in the volume is above the grow threshold. -
grow_shrink
- The volume will grow or shrink in size in response to the amount of used space.
By default,
-mode
isoff
for new flexible volumes, except for data protection (DP) mirrors, for which the default value isgrow_shrink
. Thegrow
andgrow_shrink
modes work together with Snapshot autodelete to automatically reclaim space when a volume is about to become full. The volume parameter-space-mgmt-try-first
controls the order in which these two space reclamation policies are attempted. -
[-reset <true>]
- Autosize Reset } -
Use this option to reset the values of autosize, max-autosize, min-autosize, autosize-grow-threshold-percent, autosize-shrink-threshold-percent and autosize-mode to their default values based on the current size of the volume. For example, the max-autosize value is set to 120% of the current size of the volume.
The following example sets the autosize settings on a volume named vol1. The maximum size to grow is 1TB and autogrow is enabled.
cluster1::> vol autosize vol1 -maximum-size 1t -mode grow (volume autosize) vol autosize: Flexible volume 'vs1:vol1' autosize settings UPDATED.
The following example shows the autosize settings on a volume named vol1. The maximum size to grow is 1TB and autogrow is enabled.
cluster1::> vol autosize vol1 (volume autosize) Volume autosize is currently ON for volume 'vs1:vol1'. The volume is set to grow to a maximum of 1t.
