ONTAP 9.13.1 commands
storage raid-options modify
Modify a RAID option
The storage raid-options modify command is used to modify the available RAID options for each node in a cluster. The options are described in the storage raid-options manual page.
-node {<nodename>|local} - Node
This parameter specifies the node on which the RAID option is to be modified.
-name <text> - Option Name
This parameter specifies the RAID option to be modified. To see the list of RAID options that can be modified, use the storage raid-options show command.
[-value <text>] - Option Value
This parameter specifies the value of the selected RAID option.
