volume file async-delete start
Start async delete of a directory
The volume file async-delete start
command starts async delete of a directory.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume containing the directory resides.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the name of the volume.
-path <text>
- Directory Path (privilege: advanced)-
This specifies the path of the directory.
[-throttle <integer>]
- Throttle (privilege: advanced)-
This specifies maximum number of directory delete operations per second.
The following example deletes directory "d2" under directory "d1" in volume "vol1" hosted in Vserver "vs1".
cluster1::*> volume file async-delete start -vserver vs1 -volume vol1 -path d1/d2
