The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume file async-delete start
PDF of this doc site
Creating your file...
Your file is ready
Start async delete of a directory
The volume file async-delete start
command starts async delete of a directory.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume containing the directory resides.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the name of the volume.
-path <text>
- Directory Path (privilege: advanced)-
This specifies the path of the directory.
[-throttle <integer>]
- Throttle (privilege: advanced)-
This specifies maximum number of directory delete operations per second.
The following example deletes directory "d2" under directory "d1" in volume "vol1" hosted in Vserver "vs1".
cluster1::*> volume file async-delete start -vserver vs1 -volume vol1 -path d1/d2
