volume efficiency policy modify
Modify an efficiency policy
The volume efficiency policy modify command can be used to modify the policy attributes.
The attributes of the inline-only predefined policy cannot be modified.
-vserver <vserver name>- Vserver-
This specifies the Vserver on which the volume is located.
-policy <text>- Efficiency Policy Name-
This specifies the policy name.
[-type {threshold|scheduled}]- Policy Type-
This specifies the policy type. The policy type defines when the volume using this policy will start processing a changelog. There are two possible values:
thresholdmeans changelog processing occurs when the changelog reaches a certain percentage. -
scheduledmeans changelog processing will be triggered by time.
The default value is
scheduled. -
[-schedule <text>]- Job Schedule Name-
This specifies the job schedule. Use job schedule show to show all the jobs.
[-duration <text>]- Duration-
This specifies the duration that an efficiency operation can run in hours. The possible value is between 1 and 999 inclusive.
[-start-threshold-percent <percent>]- Threshold Percentage-
The percentage at which the changelog will be processed. The percentage is checked on an hourly basis. The default value is 20. Valid only if
-typeparameter is set asthreshold. [-qos-policy {background|best_effort}]- QoS Policy-
This specifies how the efficiency operations are throttled. This option can be configured to be
backgroundorbest-effort. Default value isbest-effort. Ifbackgroundis specified, the efficiency operations are run with minimum or no impact on the data serving client operations. Ifbest-effortis specified, the efficiency operations might have some impact on the data serving client operations. [-enabled {true|false}]- Enabled-
This specifies whether the policy is enabled or not. Default value is true.
[-comment <text>]- Comment-
User specified comment.
The following example modifies efficiency policy.
cluster1::> volume efficiency policy modify -policy policy1 -schedule hourly
