volume efficiency policy modify
PDF of this doc site
Creating your file...
Modify an efficiency policy
The volume efficiency policy modify
command can be used to modify the policy attributes.
The attributes of the inline-only
predefined policy cannot be modified.
-vserver <vserver name>
- Vserver-
This specifies the Vserver on which the volume is located.
-policy <text>
- Efficiency Policy Name-
This specifies the policy name.
[-type {threshold|scheduled}]
- Policy Type-
This specifies the policy type. The policy type defines when the volume using this policy will start processing a changelog. There are two possible values:
threshold
means changelog processing occurs when the changelog reaches a certain percentage. -
scheduled
means changelog processing will be triggered by time.
The default value is
scheduled
[-schedule <text>]
- Job Schedule Name-
This specifies the job schedule. Use job schedule show to show all the jobs.
[-duration <text>]
- Duration-
This specifies the duration that an efficiency operation can run in hours. The possible value is between 1 and 999 inclusive.
[-start-threshold-percent <percent>]
- Threshold Percentage-
The percentage at which the changelog will be processed. The percentage is checked on an hourly basis. The default value is 20. Valid only if
-type
parameter is set asthreshold
. [-qos-policy {background|best_effort}]
- QoS Policy-
This specifies how the efficiency operations are throttled. This option can be configured to be
background
orbest-effort
. Default value isbest-effort
. Ifbackground
is specified, the efficiency operations are run with minimum or no impact on the data serving client operations. Ifbest-effort
is specified, the efficiency operations might have some impact on the data serving client operations. [-enabled {true|false}]
- Enabled-
This specifies whether the policy is enabled or not. Default value is true.
[-comment <text>]
- Comment-
User specified comment.
The following example modifies efficiency policy.
cluster1::> volume efficiency policy modify -policy policy1 -schedule hourly
