system controller config pci show-add-on-devices
Display PCI devices in expansion slots
The system controller config pci show-add-on-devices command displays information about the PCIe devices in I/O expansion slots. The command displays the following information about the PCIe devices:
Node
Model
Type
Slot
Device
Vendor
Sub-device ID
To display more details, use the -instance parameter.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays detailed information about PCI devices.
 [-node {<nodename>|local}]- Node-
Selects the PCI devices that are present in the specified node.
 [-model <text>]- Model String-
Selects the PCI devices that are present on the system with the specified model name.
 [-type <integer>]- Device Type-
Selects the PCI devices with the specified device type.
 [-slot-and-sub <text>]- PCI Slot Number-
Selects the PCI devices present in the specified slot or slot-subslot combination.
 [-device <text>]- Device-
Selects the PCI devices with the specified device ID.
 [-vendor <text>]- Vendor Number-
Selects the PCI devices with the specified vendor ID.
 [-sub-device-id <integer>]- Sub Device ID-
Selects the PCI devices with the specified sub-device ID.
The example below displays information about PCI devices found in I/O expansion slots of all the nodes in the cluster.
cluster1::> system controller config pci show-add-on-devices
Node               Model               Slot Type Device  Vendor Sub-Device ID
cluster1-01        FAS6240
                                          6    7  0x2532 0x1077            10
                                          5    1  0x1527 0x8086             0
                                          2    7  0x6732 0x15B3             0
                                          3    1  0x8030 0x1077             0
                                          1    2  0x8001 0x11F8             0
                                         15    1  0x10FB 0x8086             0
                                         13    1  0x150E 0x8086             1
                                          7    1  0x1528 0x8086             0
cluster1-02        FAS6240
                                          5    1  0x1527 0x8086             0
                                          2    7  0x6732 0x15B3             0
                                          3    1  0x8030 0x1077             0
                                          1    2  0x8001 0x11F8             0
                                          7    1  0x1528 0x8086             0
16 entries were displayed.
cluster1::>
