system controller config pci show-add-on-devices
Display PCI devices in expansion slots
The system controller config pci show-add-on-devices
command displays information about the PCIe devices in I/O expansion slots. The command displays the following information about the PCIe devices:
Node
Model
Type
Slot
Device
Vendor
Sub-device ID
To display more details, use the -instance parameter.
[-fields <fieldname>,…]
Selects the fields that you specify.
[-instance ]
Displays detailed information about PCI devices.
[-node {<nodename>|local}]
- Node-
Selects the PCI devices that are present in the specified node.
[-model <text>]
- Model String-
Selects the PCI devices that are present on the system with the specified model name.
[-type <integer>]
- Device Type-
Selects the PCI devices with the specified device type.
[-slot-and-sub <text>]
- PCI Slot Number-
Selects the PCI devices present in the specified slot or slot-subslot combination.
[-device <text>]
- Device-
Selects the PCI devices with the specified device ID.
[-vendor <text>]
- Vendor Number-
Selects the PCI devices with the specified vendor ID.
[-sub-device-id <integer>]
- Sub Device ID-
Selects the PCI devices with the specified sub-device ID.
The example below displays information about PCI devices found in I/O expansion slots of all the nodes in the cluster.
cluster1::> system controller config pci show-add-on-devices Node Model Slot Type Device Vendor Sub-Device ID ------------------ ------------------- ---- ---- ------- ------ ------------- cluster1-01 FAS6240 6 7 0x2532 0x1077 10 5 1 0x1527 0x8086 0 2 7 0x6732 0x15B3 0 3 1 0x8030 0x1077 0 1 2 0x8001 0x11F8 0 15 1 0x10FB 0x8086 0 13 1 0x150E 0x8086 1 7 1 0x1528 0x8086 0 cluster1-02 FAS6240 6 7 0x2532 0x1077 10 5 1 0x1527 0x8086 0 2 7 0x6732 0x15B3 0 3 1 0x8030 0x1077 0 1 2 0x8001 0x11F8 0 15 1 0x10FB 0x8086 0 13 1 0x150E 0x8086 1 7 1 0x1528 0x8086 0 16 entries were displayed. cluster1::>
