ONTAP commands
network qos-marking modify
Modify the QoS marking values
The network qos-marking modify command modifies the QoS marking values for different protocols, for each IPspace.
-ipspace <IPspace> - IPspace name
Use this parameter to specify the IPspace for which the QoS marking entry is to be modified.
-protocol <text> - Protocol
Use this parameter to specify the protocol for which the QoS marking entry is to be modified. The possible values are NFS, CIFS, iSCSI, NVMe-TCP, SnapMirror, SnapMirror-Sync, NDMP, FTP, HTTP-admin, HTTP-filesrv, SSH, Telnet, and SNMP.
[-dscp <integer>] - DSCP Marking Value
Use this parameter to specify the DSCP value. The possible values are 0 to 63.
[-is-enabled {true|false}] - Is QoS Marking Enabled
Use this parameter to enable or disable the QoS marking for the specified protocol and IPspace.
The following example modifies the QoS marking entry for the NFS protocol in the Default IPspace:
cluster1::> network qos-marking modify -ipspace Default -protocol NFS -dscp 10 -is-enabled true
