      storage automated-working-set-analyzer start
Command to start Automated Working Set Analyzer on node or aggregate
The automated-working-set-analyzer start command enables the Automated Workload Analyzer that is capable of doing the following:
Flash Pool modeling for an aggregate
Flash Cache modeling for a node - can not specify an aggregate.
Working set size estimation
Workload monitoring
- -node <nodename>- Node Name (privilege: advanced)
This parameter indicates the node name that the AWA instance runs on.
- [-flash-cache {true|false}]- Flash Cache Node-wide Modeling (privilege: advanced)
This parameter indicates whether the AWA is modeling flash-cache.
- [-aggregate <aggregate name>]- Aggregate (privilege: advanced)
This parameter indicates the aggregate name that the AWA instance runs on.
- [-working-set-size {true|false}]- Working Set Size (privilege: advanced)
This parameter indicates whether the AWA instance is configured to find the working set size.
cluster1::> storage automated-working-set-analyzer start -node vsim1 -aggregate aggr0
 PDFs
PDFs
