The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network ndp default-router delete-all
PDF of this doc site
Creating your file...
Your file is ready
Delete default routers on a given IPspace
The network ndp default-router delete-all
command deletes default router lists from the specified IPspace.
-ipspace <IPspace>
- IPspace Name (privilege: advanced)-
Use this parameter to specify the IPspace where the default routers are to be deleted.
The following example deletes default routers from IPspace ips1.
cluster1::*> network ndp default-router delete-all -ipspace ips1
