vserver cifs share access-control delete
Delete an access control list
The vserver cifs share access-control delete command deletes a user or group from a CIFS share's ACL.
- -vserver <vserver name>- Vserver
This parameter specifies the name of the Vserver containing the CIFS share.
- -share <Share>- Share Name
This parameter specifies the name of the CIFS share.
- -user-or-group <TextNoCase>- User/Group Name
This parameter specifies the user or group to delete from the CIFS share's access control list. If you specify a user name, you must include the user's domain using the format "domain\username". The user-or-group parameter is case-insensitive text.
- [-user-group-type {windows|unix-user|unix-group}]- User or Group Type
This parameter specifies the type of the user or group to delete from the CIFS share's access control list. The default type is windows. The user-group-type can be one of the following: -
windows
unix-user
unix-group
The following example deletes the group "Everyone" for the access control list of share "vol3".
vs1::> vserver cifs share access-control delete -share vol3 -user-or-group Everyone
 PDFs
PDFs
