Command reference
vserver cifs share access-control delete
Delete an access control list
The vserver cifs share access-control delete command deletes a user or group from a CIFS share's ACL.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver containing the CIFS share.
-share <Share> - Share Name
This parameter specifies the name of the CIFS share.
-user-or-group <TextNoCase> - User/Group Name
This parameter specifies the user or group to delete from the CIFS share's access control list. If you specify a user name, you must include the user's domain using the format "domain\username". The user-or-group parameter is case-insensitive text.
[-user-group-type {windows|unix-user|unix-group}] - User or Group Type
This parameter specifies the type of the user or group to delete from the CIFS share's access control list. The default type is windows. The user-group-type can be one of the following:
  • windows
  • unix-user
  • unix-group
The following example deletes the group "Everyone" for the access control list of share "vol3".
vs1::> vserver cifs share access-control delete -share vol3 -user-or-group Everyone
