cluster add-node-status
Show cluster expansion progress
The cluster add-node-status command displays the progress of the node joining a cluster initiated by using the cluster create command or the cluster add-node command
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node-uuid <UUID>]- Node UUID-
Select the node that match the specified node UUID.
[-node-name <text>]- Node Name-
Select the nodes that match the specified node name.
[-cluster-ip <IP Address>]- IP Address of a Cluster Interface of Node-
Select the nodes that match the specified cluster IP.
[-status <Cluster Operation Status>]- The Status of Current Task Being Performed-
Select the nodes that match the specified status. This status shows whether the operation is ongoing or complete with success or failure. The various phases that a node goes through are node-initialization, joining-cluster, service-startup, post-cluster-setup and success or failure.
[-failure-msg <text>]- Error Reason-
Select the nodes that match the specified error string.
[-last-updated <MM/DD/YYYY HH:MM:SS>]- Last Updated-
The date/time stamp of the last update to the status.
The following example shows the progress of a node add operation:
clus1::> cluster add-node-status
Node Name Node IP Status Error Reason
node1 1.1.1.1 success -
