Command reference
cluster add-node-status
Show cluster expansion progress
The cluster add-node-status command displays the progress of the node joining a cluster initiated by using the cluster create command or the cluster add-node command
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node-uuid <UUID>] - Node UUID
Select the node that match the specified node UUID.
[-node-name <text>] - Node Name
Select the nodes that match the specified node name.
[-cluster-ip <IP Address>] - IP Address of a Cluster Interface of Node
Select the nodes that match the specified cluster IP.
[-status <Cluster Operation Status>] - The Status of Current Task Being Performed
Select the nodes that match the specified status. This status shows whether the operation is ongoing or complete with success or failure. The various phases that a node goes through are node-initialization, joining-cluster, service-startup, post-cluster-setup and success or failure.
[-failure-msg <text>] - Error Reason
Select the nodes that match the specified error string.
[-last-updated <MM/DD/YYYY HH:MM:SS>] - Last Updated
The date/time stamp of the last update to the status.
The following example shows the progress of a node add operation:
clus1::> cluster add-node-status
        Node Name       Node IP           Status         Error Reason
        node1           1.1.1.1           success        -
