cluster create
Create a cluster
The cluster create command creates a cluster with one or more nodes. When the -node-count parameter is specified, the command attempts to add that many nodes to the cluster. The -cluster-ips parameter can be specified to add one or more nodes in parallel. Only one of the -node-count and -cluster-ips parameters can be provided.
Note that single-node clusters do not require configuring the cluster network. A cluster network interface must be configured before other nodes can join the cluster.
The node-count parameter is deprecated and may be removed in a future release of ONTAP. Use the -cluster-ips parameter instead.
[-license <License Code V2>]- (DEPRECATED)-Base License-
This parameter is deprecated and may be removed in a future release of ONTAP. Use this optional parameter to specify the base license for the cluster. Obtain this value from your sales or support representative.
 -clustername <text>- Cluster Name-
Use this parameter to specify the name of the cluster you are creating.
The name must contain only the following characters: A-Z, a-z, 0-9, "-" or "_".
The first character must be one of the following characters: A-Z or a-z.
The last character must be one of the following characters: A-Z, a-z or 0-9.
The maximum supported length is 44 characters.
The system reserves the following names: "all", "cluster", "local" and "localhost".
[-cluster-ips <IP Address>,…]- List of Cluster Interface IP Addresses of the Nodes Being Added -
This parameter contains a comma separated list of cluster interface IP addresses of the nodes in the cluster you are creating. All the nodes specified in the list will be added to the cluster.
[-node-count <integer>]- (DEPRECATED)-Node Count -
Use this parameter to specify the number of nodes in the cluster you are creating.
-node-countparameter is supported on non-shared architecture platforms only.
 [-node-names <text>,…]- List of Node Names-
This parameter contains a comma separated list of node names of all the nodes in the cluster you are creating. The node names must have an one to one correspondence with
-cluster-ipsparameter. The names provided will be used to rename the nodes once they are added to the cluster. - |
-retry <true>- Retry a failed cluster create operation } -
Use this parameter to retry the most recently failed
cluster createcommand with the originally specified parameters. Retry is not supported if thecluster createcommand was originally run with either the-node-countor-node-ipparameters.
The following example creates a cluster named cluster1
cluster1::> cluster create -clustername cluster1
The following example creates a cluster named cluster1 with node-count 4 on a non-shared architecture platform.
cluster1::> cluster create -clustername cluster1 -node-count 4
