cluster space show
PDF of this doc site
Creating your file...
Your file is ready
Displays Cluster Space Information
The cluster space show
command displays information about space usage within the cluster. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all clusters.
