Command reference
security login duo show
Display Duo Configurations
The security login duo show command displays information about the Duo configurations.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects the Duo configuration Vserver that match this parameter value.
[-is-enabled {true|false}] - Duo Enable Status
Selects the Duo Configurations that match this parameter value.
[-integration-key <text>] - Duo Intgration Key
[-fingerprint <text>] - Duo Secret Key Fingerprint
[-apihost <text>] - Duo API Host
[-autopush {true|false}] - Duo Auto Push Config
[-pushinfo {true|false}] - Information with Push
[-fail-mode {safe|secure}] - Duo Fail Safe Config
[-http-proxy <text>] - HTTP Proxy URL with Port Number
[-max-prompts <integer>] - Duo Max Attempts
[-status <text>] - Duo Status
[-comment <text>] - Comment
The example below displays the Duo information for the Vserver VS1.
cluster1::> security login duo show
                    Vserver: VS1
                    Enabled: true
                     Status: OK
            Integration Key: AA11A1AAAA1AAAA11A1A
            SHA Fingerprint:
            xxxxxxxxxx11111111117bd5a3b060947b617355ecf353627c50b1xxxxxxxxxx
                   API Host: api-xxxxxxx.duosecurity.com
                   Autopush: true
                  Push info: true
                   Failmode: safe
                 Http-proxy: -
                    Prompts: 1
              Comment: This is a new key
