security login duo show
Display Duo Configurations
The security login duo show command displays information about the Duo configurations.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Selects the Duo configuration Vserver that match this parameter value.
[-is-enabled {true|false}]- Duo Enable Status-
Selects the Duo Configurations that match this parameter value.
[-integration-key <text>]- Duo Intgration Key-
[-fingerprint <text>]- Duo Secret Key Fingerprint-
[-apihost <text>]- Duo API Host-
[-autopush {true|false}]- Duo Auto Push Config-
[-pushinfo {true|false}]- Information with Push-
[-fail-mode {safe|secure}]- Duo Fail Safe Config-
[-http-proxy <text>]- HTTP Proxy URL with Port Number-
[-max-prompts <integer>]- Duo Max Attempts-
[-status <text>]- Duo Status-
[-comment <text>]- Comment-
The example below displays the Duo information for the Vserver VS1.
cluster1::> security login duo show
Vserver: VS1
Enabled: true
Status: OK
Integration Key: AA11A1AAAA1AAAA11A1A
SHA Fingerprint:
xxxxxxxxxx11111111117bd5a3b060947b617355ecf353627c50b1xxxxxxxxxx
API Host: api-xxxxxxx.duosecurity.com
Autopush: true
Push info: true
Failmode: safe
Http-proxy: -
Prompts: 1
Comment: This is a new key
