system controller bezel-led show
Display the state of the bezel LED logo (lit or unlit)
The system controller bezel-led show command shows the current illumination state of the bezel LED logo (lit or unlit).
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
The node whose bezel LED logo illumination state is being shown.
[-state {off|on|disconnected|bezel-switch|unknown}]- Bezel LED Logo State-
The bezel LED logo illumination state of the node.
The following example lists the current illumination state of the bezel LED logo:
cluster1::> system controller bezel-led show Node Bezel LED Logo State -------------- -------------------- node1 off node2 off
