Command reference
security login duo group show
Display Duo Group Configurations
The security login duo group show command displays information about Duo groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects the Vserver that match this parameter value.
[-group-name <text>] - Group Name
Selects the groups that match this parameter value.
[-excluded-users <text>,…​] - List of Excluded Users
Selects the excluded users that match this parameter value.
[-comment <text>] - Comment
Selects the comments that match this parameter value.
The example below displays group information for the Vserver vs1.
cluster1::> security login duo group show -vserver vs1
Vserver: vs1
Group Name: NETAPP_ENG
Excluded Users: user1, user2, user12
Comment: This is a new group
