security login duo group show
Display Duo Group Configurations
The security login duo group show command displays information about Duo groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Selects the Vserver that match this parameter value.
[-group-name <text>]- Group Name-
Selects the groups that match this parameter value.
[-excluded-users <text>,…]- List of Excluded Users-
Selects the excluded users that match this parameter value.
[-comment <text>]- Comment-
Selects the comments that match this parameter value.
The example below displays group information for the Vserver vs1.
cluster1::> security login duo group show -vserver vs1 Vserver: vs1 Group Name: NETAPP_ENG Excluded Users: user1, user2, user12 Comment: This is a new group
