The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver vscan on-demand-task run
PDF of this doc site
Creating your file...
Your file is ready
Run an On-Demand task
The vserver vscan on-demand-task run
command start virus scanning immediately for an On-Demand task.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver on which you want to start start virus scanning.
-task-name <text>
- Task Name-
This parameter specifies the name of the On-Demand task that you want to start virus scanning.
The following example starts virus scanning an On-Demand task:
cluster1::> vserver vscan on-demand-task run -vserver vs1 -task-name t1 [Job 161]: Vscan On-Demand job is queued. Use the "job show -id 161" command to view the status.
