network port broadcast-domain remove-ports
Remove ports from a layer 2 broadcast domain
Remove port assignments from a broadcast domain.
-ipspace <IPspace>- IPspace Name-
The IPspace of the broadcast domain.
-broadcast-domain <Broadcast Domain>- Layer 2 Broadcast Domain-
The broadcast domain of the ports.
-ports [node>:<port],…- List of ports-
The ports to removed from the broadcast-domain.
The following example removes port "e0d" on node "cluster1-1" and port "e0d" on node "cluster1-2" from broadcast domain "mgmt" in IPspace "Default".
cluster1::network port broadcast-domain> remove-ports -ipspace Default -broadcast-domain mgmt -ports cluster1-1:e0d, cluster1-2:e0d
