vserver vscan on-access-policy enable
PDF of this doc site
Creating your file...
Enable an On-Access policy
The vserver vscan on-access-policy enable
command enables an On-Access policy for the specified Vserver. Only one On-Access policy of a specific protocol can be enabled at one time.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver on which you want to enable an On-Access policy. The Vserver administrator can enable On-Access policy created within the scope of the Vserver or the cluster. The cluster administrator can enable On-Access policy for any Vserver but cannot enable them with a scope of cluster. The scope is determined at a Vserver level.
-policy-name <Policy name>
- Policy-
This parameter specifies the name of the On-Access policy you want to enable.
The following command enables an On-Access policy on specified Vserver.
cluster1::> vserver vscan on-access-policy enable -vserver vs1 -policy-name new cluster1::> vserver vscan on-access-policy show -instance -vserver vs1 -policy-name new Vserver: vs1 Policy: new Policy Status: on Policy Config Owner: vserver File-Access Protocol: CIFS Filters: scan-ro-volume Mandatory Scan: on Max File Size Allowed for Scanning: 4GB File-Paths Not to Scan: \vol\temp File-Extensions Not to Scan: txt
