      vserver audit audit-log-redirect modify
Modify Audit Log Redirect Vserver destination
The vserver audit audit-log-redirect modify command changes the dedicated Vserver for all audit logs in a cluster to reside in.
- [-vserver <vserver name>]- Audit Log Redirect Vserver (privilege: advanced)
Use this parameter to specify a dedicated Vserver for all audit logs to reside in.
The following example modify the current audit-log-redirect Vserver to vserver1 :
cluster1::> vserver audit audit-log-redirect modify -vserver vserver1
 PDFs
PDFs
