vserver audit audit-log-redirect modify
PDF of this doc site
Creating your file...
Your file is ready
Modify Audit Log Redirect Vserver destination
The vserver audit audit-log-redirect modify
command changes the dedicated Vserver for all audit logs in a cluster to reside in.
[-vserver <vserver name>]
- Audit Log Redirect Vserver (privilege: advanced)-
Use this parameter to specify a dedicated Vserver for all audit logs to reside in.
The following example modify the current audit-log-redirect Vserver to vserver1
cluster1::> vserver audit audit-log-redirect modify -vserver vserver1
