The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
metrocluster check config-replication show-capture-status
PDF of this doc site
Creating your file...
Your file is ready
Display MetroCluster capture status information
The metrocluster check config-replication show-capture-status
command indicates whether or not a configuration change that would prevent a negotiated switchover is currently being captured for replication.
The following example shows the execution of the command in a MetroCluster configuration when capture is not in progress:
cluster1::*> metrocluster check config-replication show-capture-status Is Capture in Progress: false
