lun igroup initiator add-proximal-vserver
Add a Vserver to the initiator's proximal list
This command is used to configure which site in a SnapMirror Business Continuity (SM-BC) relationship is proximal with the provided FCP or iSCSI initiator.
-vserver <Vserver Name>- Vserver (privilege: advanced)-
Specifies the name of the Vserver the initiator will access.
-initiator <text>- Initiator (privilege: advanced)-
Specifies the FCP WWPN or iSCSI IQN of the initiator.
-proximal-vservers <text>,…- Proximal Vserver Name (privilege: advanced)-
Specifies the name of the Vserver to configure as proximal. The specified Vserver must either be the same as the
-vserverparameter or a Vserver in a peer relationship withsnapmirroras an allowed application. [-replace <true>]- Replace Existing (privilege: advanced)-
If true, replace all existing
-proximal-vserversfor the initiator with the ones specified. By default, the specified-proximal-vserversare added to any existing values.
The following example configures iqn.2001-04.com.example:uefi-0232314 in Vserver local-vserver as proximal to the peer-vserver Vserver:
cluster1::*> lun igroup initiator add-proximal-vserver -vserver local-vserver -initiator iqn.2001-04.com.example:uefi-0232314 -proximal-vservers peer-vserver
