ONTAP commands
vserver nfs prepare-to-downgrade
Remove NFS configurations that are not compatible with earlier versions of Data ONTAP
The vserver nfs prepare-to-downgrade command removes NFS configurations incompatible with the earlier release of Data ONTAP.
-disable-feature-set <downgrade version> - Data ONTAP Version (privilege: advanced)
This parameter specifies the Data ONTAP version that introduced the new NFS configurations and needs to be removed before downgrade. The value can be one of the following:
  • 9.2.0 - Remove the NFS configurations introduced in Data ONTAP release 9.2.0. The configurations include the following:
  • -file-session-io-grouping-count .
  • -file-session-io-grouping duration .
cluster1::*> vserver nfs prepare-to-downgrade -disable-feature-set 9.2.0
