event notification destination prepare-for-revert
Deletes or updates unsupported syslog destinations (transport=TCP or transport=UDP with non-default configurations: port, message-format, timestamp-format-override, hostname-format-override)
The event notification destination prepare-for-revert can be used to remove or update syslog notification destinations that are not supported when the cluster reverts to the previous release. Supported syslog destinations are ones with udp-unencryptedsyslog-transport using syslog-port 514  and legacy_netappsyslog-message-format with syslog-timestamp-format-override and syslog-hostname-format-override both set to no-override . Syslog destinations with any other configurations are not supported.
- { -delete-unsupported-syslog-destinations {true|false}- Clear unsupported syslog destinations (privilege: advanced)
Use this parameter to delete syslog destinations that are not supported in the previous release.
- | -update-unsupported-syslog-destinations {true|false}- Update unsupported syslog destinations to supported (privilege: advanced) }
Use this parameter to update syslog destinations that are not supported in the previous release with supported configurations.
The following shows examples of "event notification destination prepare-for-revert":
cluster1::*> event notification destination show Name Type Destination -------------- ---------- --------------------- snmp-traphost snmp - (from "system snmp traphost") tst01 syslog test.com (port: 6514, transport: tcp-encrypted) tst02 syslog test.com (port: 601, transport: tcp-unencrypted) tst03 syslog test.com (port: 1234, transport: udp-unencrypted) tst04 syslog test.com (port: 514, transport: udp-unencrypted) 5 entries were displayed. cluster1::*> event notification destination prepare-for-revert -delete-unsupported-syslog-destinations true cluster1::*> event notification destination show Name Type Destination -------------- ---------- --------------------- snmp-traphost snmp - (from "system snmp traphost") tst04 syslog test.com (port: 514, transport: udp-unencrypted) 2 entries were displayed.
 PDFs
PDFs
