network connections active show-lifs
Show a count of the active connections by logical interface
The network connections active show-lifs command displays the number of active connections on each logical interface, organized by node and Vserver.
Note The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Use this parameter to display information only about the connections on the node you specify.
[-vserver <vserver>] - Vserver
Use this parameter to display information only about the connections that are using the node or Vserver you specify.
[-lif-name <lif-name>] - Logical Interface Name
Use this parameter to display information only about the connections that are using the logical interface you specify.
[-count <integer>] - Client Count
Use this parameter to display only logical interfaces with the number of active client connections you specify.
[-blocked-count <integer>] - (DEPRECATED)-Load Balancing Blocking Count
Note This parameter has been deprecated and may be removed in a future version of Data ONTAP.
Use this parameter to display information only about data logical interfaces blocked from migrating and the connection that is blocking it.
The following example displays information about the servers and logical interfaces being used by all active connections:
cluster1::> network connections active show-lifs
Node      Vserver Name  Interface Name  Count
node0
          vs0           datalif1             3
          vs0           cluslif1             6
          vs0           cluslif2             5
node1
          vs0           datalif2             3
          vs0           cluslif1             3
          vs0           cluslif2             5
node2
          vs1           datalif2             1
          vs1           cluslif1             5
          vs1           cluslif2             3
node3
          vs1           datalif1             1
          vs1           cluslif1             2
          vs1           cluslif2             1
At privilege levels above "admin", the command displays an extra column.
cluster1::*> network connections active show-lifs
                                               LB Migrate
Node      Vserver Name  Interface Name  Count  Blocking
node0
          vs0           datalif1             3          0
          vs0           cluslif1             6          0
          vs0           cluslif2             5          2
node1
          vs0           datalif2             3          0
          vs0           cluslif1             3          0
          vs0           cluslif2             5          0
node2
          vs1           datalif2             1          0
          vs1           cluslif1             5          0
          vs1           cluslif2             3          2
node3
          vs1           datalif1             1          0
          vs1           cluslif1             2          0
          vs1           cluslif2             1          0
