network connections active show-lifs
Show a count of the active connections by logical interface
The network connections active show-lifs command displays the number of active connections on each logical interface, organized by node and Vserver.
The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to display information only about the connections on the node you specify.
[-vserver <vserver>]- Vserver-
Use this parameter to display information only about the connections that are using the node or Vserver you specify.
[-lif-name <lif-name>]- Logical Interface Name-
Use this parameter to display information only about the connections that are using the logical interface you specify.
[-count <integer>]- Client Count-
Use this parameter to display only logical interfaces with the number of active client connections you specify.
[-blocked-count <integer>]- (DEPRECATED)-Load Balancing Blocking Count-
This parameter has been deprecated and may be removed in a future version of Data ONTAP. Use this parameter to display information only about data logical interfaces blocked from migrating and the connection that is blocking it.
The following example displays information about the servers and logical interfaces being used by all active connections:
cluster1::> network connections active show-lifs
Node Vserver Name Interface Name Count
node0
vs0 datalif1 3
vs0 cluslif1 6
vs0 cluslif2 5
node1
vs0 datalif2 3
vs0 cluslif1 3
vs0 cluslif2 5
node2
vs1 datalif2 1
vs1 cluslif1 5
vs1 cluslif2 3
node3
vs1 datalif1 1
vs1 cluslif1 2
vs1 cluslif2 1
